- Fri Apr 07, 2017 5:41 pm
#194308
Hi!
I've developed an ECG acquisition circuit that will acquire an ECG signal using a high CMRR, and uses active lowpass and highpass filters to filter the signal to a desired frequency range (0.5 - 150 Hz).
My signal output is clear but it is usually between -0.2 and +0.2 Volts and sometimes as small as -0.1V and +0.1 Volts.
I'm trying to apply a DC offset to this signal so that I can read it into an Arduino Mega (which can only read in voltages from 0-5V!) using AnalogRead() ?
I've tried to use a positive clamper circuit but my signal is too small to overcome the bias voltage of a diode!
Any suggestions as to how to get my signal in the positive range, without causing issues with my upstream ECG circuit?
Thanks so much!
Thanks so much!
