GetImage from GT-511C3 Fingerprint Scanner in Arduino/Teensy
maitreyamaity
Post by maitreyamaity » Mon Jan 23, 2017 3:34 pm
The fingerprint sensor is Fingerprint Scanner - TTL (GT-511C3) (https://www.sparkfun.com/products/11792)
The getImage function is incomplete in the given library (https://github.com/sparkfun/Fingerprint_Scanner-TTL).
The FPS device communicates with Arduino perfectly. Now, I want to get the fingerprint image directly from the FPS when I press on the scanner. I need the image to store separately on SD card. Please help me with code sample for getImage.
Thanking you
Regards
Maitreya
maitreyamaity
Re: GetImage from GT-511C3 Fingerprint Scanner in Arduino/Te
Post by maitreyamaity » Sat Jan 28, 2017 4:39 am
I am able to receive 52116 bytes for getImage function. Need help on how to reconstruct image from received data.
kushalsharma07
Re: GetImage from GT-511C3 Fingerprint Scanner in Arduino/Teensy
Post by kushalsharma07 » Tue Dec 12, 2017 3:39 am
Did you find solution for this problem?
rcwilcox
Post by rcwilcox » Tue Dec 12, 2017 10:59 am
getImage appears to be eight bits deep (258 row x 202 col, or vice versa) - Try http://matplotlib.org/ (Python) or similar image processing S/W to plot it out.
