- Sat Mar 19, 2016 5:34 pm
#188779
I am using an arduino leonardo and ITG-3200 gyroscope. I followed the directions to hook the two components up as well as used the code from this website https://learn.sparkfun.com/tutorials/it ... okup-guide
I was able to get readings from the gyroscope at one point but now all I get are zeroes. I also don't get a correct address reading from the gyroscope (just zeroes as well). To troubleshoot this problem, I probed VCC and VIO (which are at 3.3 V) and SCL and SDA (which both increased in voltage when the gyroscope moved more). I've tried different ways of connecting the pins in case there was a faulty wire but nothing has worked
Does anybody have any suggestions?
Thank you,
Valerie
Thank you,
Valerie
