- Thu Sep 20, 2012 10:45 pm
#149645
Hi, I'm new to Arduino and am currently using it for my Final Year Project in my university. I proposed to come up with an Intelligent Car Park system where drivers can check for availability of parking berths in a car park wirelessly using their mobile devices.
I am now working on the programming on Arduino, and am faced with a situation. I currently have 2 PIR sensors in my circuit, and I wish to have them both work simultaneously. However, I can only get readings from either one of the sensors at one particular time in the Serial Monitor. I suspect it is because I put the coding for the functionality of both sensors in one loop as shown in the coding below.
Thank you in advance for your help
If both sensors detect motion at a particular time, eg. at 100 seconds, only readings from a sensor can be obtained on the Serial Monitor. I tried separating the coding for the functionality of each sensor into one loop in itself, but I realized Arduino programming only allows one loop in a program. Hence, I'd like to know if there is any way I can separate the coding, or if there is any way I can get readings from both sensors at one time. void loop(){
if(digitalRead(pirPin1) == HIGH){
digitalWrite(ledPin1, HIGH); //the led visualizes the sensors output pin state
if(lockLow){
//makes sure we wait for a transition to LOW before any further output is made:
lockLow = false;
Serial.println("---");
Serial.print("Motion detected at Sensor 1 at ");
Serial.print(millis()/1000);
Serial.println(" sec");
delay(50);
takeLowTime = true;
if(digitalRead(pirPin1) == LOW){
digitalWrite(ledPin1, LOW); //the led visualizes the sensors output pin state
if(takeLowTime){
lowIn = millis(); //save the time of the transition from high to LOW
takeLowTime = false; //make sure this is only done at the start of a LOW phase
//if the sensor is low for more than the given pause,
//we assume that no more motion is going to happen
if(!lockLow && millis() - lowIn > pause){
//makes sure this block of code is only executed again after
//a new motion sequence has been detected
lockLow = true;
Serial.print("Motion ended at Sensor 1 at "); //output
Serial.print((millis() - pause)/1000);
delay(50);
if(digitalRead(pirPin2) == HIGH){
digitalWrite(ledPin2, HIGH); //the led visualizes the sensors output pin state
if(lockLow){
lockLow = false;
Serial.print("Motion detected at Sensor 2 at ");
delay(50);
takeLowTime = true;
if(digitalRead(pirPin2) == LOW){
digitalWrite(ledPin2, LOW); //the led visualizes the sensors output pin state
if(takeLowTime){
lockLow = true;
Serial.print("Motion ended at Sensor 2 at "); //output
delay(50);
