- Wed May 18, 2011 3:13 am
#127399
Hello to all on this forum, this is my first post here.
I have recently purchased my first Arduino and I wanted to test it out with a stepper motor.
So I also purchased EasyDriver and Mercury Stepper motor (ROB-09238).
I connected Stepper motor to EasyDriver in this order: Red, Green, Yellow, Blue.
EasyDriver is powered from Arduino 5V and 2 GND wires are soldered together and grounded next to 5V on Arduino.
To power the Stepper motor 12V rail of old PC ATX power supply is used. To much ??
Direction and Step are Pinout 3 and 4.
Ok, the problem.
When I connect Arduino to PC using USB Stepper motor starts to turn, sloooowly and this is before I turn on the 12v power to the motor. With 12v turned on, motor stops and doesn't react to commands. I tried to disconnect the step and direction and it still goes round and round sloowly but only if 12V is not turned on.
So I have Arduino + EasyDriver + Mercury Stepper with EasyDriver connected only to 5V and GRN on Arduino and stepper is turning. If power (Mercury is rated at 12V) is turned on it stops.
I have attached an picture of my current wiring. Please note that Green and Brown wires are not connected to Arduino but the stepper motor is still turning slowly.
Any Ideas as to why this is happening?
Thanks
Ok, the problem.
Thanks
