- Sat Feb 19, 2011 12:42 pm
#120695
So I just recently finished a standalone pcb utilizing the atmega1280 chip. I have wrote all the code in the arduino IDE. I would like to be able to use the existing code I have written and upload it through AVR studio 4. Last night I uploaded the *.hex file in avr studio that was generated in the arduino IDE but nothing seemed to work correctly. The atmega1280 of course has no bootloader, but from what i've read as long as your using the MKII you shouldn't need the bootloader. The hex file that I uploaded programmed fine but nothing was working correctly. There's an lcd, buttons, buzzers, mosfets... all that jazz. So I decided to try the bootloader. I used the atmega1280 bootloader supplied with the arduino IDE files, but it bricked the chip (Changed the fuse settings) - probably from my lack of experience. The only way to recover would be to use a HVPP I suppose.
I'm going to build another board today, but i don't want a repeat of last night. Will the hex file work without the bootloader, I see in avrstudio all the pins are mapped using a different method, not using the pinMode(53, OUTPUT); could this be what the bootloader assists with or is the bootloader just for say using a USB instead of a programmer like the MKII.
I have done lots of research but no straight forward answers that I can find. Any help is greatly Appreciated.
Also whats the *.ELF file smiley-sad
Thanks a bunch
Geoff
Thanks a bunch
Geoff
