- Fri Feb 18, 2011 9:30 am
#120597
Not sure if this is the right place to ask this, but here goes!
I've done a couple projects using the SF Inventor kit, and have a *basic* grasp of electrical thoery, but just wanted to bounce this off some more experienced minds before I made it out on a perf board.
Making a small simple LED display using 10 LEDs, thrown HIGH and LOW by an UNO via its IO pins. Basic flashing patterns.
Would it be sane to wire all the cathodes together and use a single resistor (higher value than if 1 R per LED) to ground? At any given time only two LEDs will be lit, so should I calculate for 40mA of current, as opposed to the 20mA per pin?
Is this set up sane, or should I just do a single R per LED?
Thanks! I'm an IT guy trying to get more involved in physical computing, and a lot of this stuff just flies over my head, beyond White to White, Black to Black, Green to Green
