- Tue Jan 11, 2011 10:02 am
#117095
I have a need for a device that measures compliance with hand gel use and communicates through our existing wifi network.
I have a feature set in mind and I need help with deciding what to purchase in order to make the prototype.
This project should be self powered. It should fit in a box small enough and light enough that double stick tape could be used to fasten it to a hand gel station.
When someone walks past the station, a motion detector picks up that event and tallies the number.
Then the device listens for 10 seconds for a signal from an accelerometer sensitive enough to detect if the gel station has been used. If the gel station is used in 10 seconds (programable value) that number is tallied in a second register.
If the acceleration is not detected in 10 seconds, a buzzer sounds along with an LED enunciator blink and this is tallied in a third register.
Unit resets.
Register 1: Potential gel users
Register 2: gel users
Register 3: didn't use gel
The buzzer and LED blinking behavior can be modified in the following ways:
1. Data collection mode: buzzer and LED are inactive, unit only collects data.
2. Normal Mode: Buzzer and LED are active and influence behavior (hopefully).
3. Patient Room Mode: Day/night cycle for buzzer. Off during night time hours, LED functions normally.
The data is uploaded once every 24 hours by wifi to a networked computer, hopefully to a spreadsheet program or to its own web page. The behavior of the buzzer and LED can be changed remotely to one of the three modes above.
This device should be able to work in conjunction with up to several hundred other devices at a time to give data as a whole, in subsets by area installed, and individually. I would like to build from 2 to five at first.
Sounds easy right?
I may be in over my head. So if anyone wants to bid on this project, I'll consider that also.
Thanks,
-Spencer
Unit resets.
Sounds easy right?
Thanks,
-Spencer
