- Wed Dec 29, 2010 10:53 pm
#116327
Is there any way to adjust the input pin sensitivity on an Arduino Uno? My Arduino will literally detect inputs from my mere proximity to the board when the input being used has a wire lead coming from it.
Edit: Since I'm already asking for help, I've encountered another problem and I'm in need of some advice.
My goal is to take feedback from 3 different on/off switches independently and light LEDs according to a pattern determined by what switches are pressed. I was drawing power from the 5V pin, connecting three switches to power in parallel, running a lead after each switch to the Digital Input Pins, then a diode, then joining all three leads together again with a resistor before connecting to ground. My sketch (which I believe is okay) does not run with this circuit. No matter what switch is closed, the Arduino runs the loop inside main() endlessly.
Thank you for the help!
