- Wed Mar 05, 2008 4:06 pm
#44085
Hello All -
I'm designing my first PCB (2 layer) based off of this schematic. http://home.comcast.net/~houta69/M1-R.bmp
My background is in software and my hardware skills leave a lot to be desired. One thing that I'm very confussed about is the proper grounding to use on the board. I've seen where the ground rail is provided with a big fat trace running around the perimeter of the board, others recommend providing a ground plane. I've seen recomendations for seperate ground planes that tie back together at the supply if RF or mixed analog and digital circuits are used. I've also read arguments for using a single ground plane for the entire board regardless of the circuitry involved.
I was hoping that someone might shed a little additional light on this topic for me. Are there general rules of thumb for which techniques should be used in a given situation or is every situation completely unique?
This is also my first CAD schematic diagram, so any critiquing of that is welcomed too.
Thanks much
Thanks much
-Adam
