- Tue Feb 05, 2008 10:22 am
#42277
So I just clued in that you are trying to drive the SFE dual-color matrix display. That answers why you drive 8 LEDs at a time but have 16 current limiting resistors (2 colors). However, the big issue is that when you drive a single row of 8 LEDs, all the current will return on a single column pin. So while each LED might draw 9ma, with them all on, you need to return 72ma on a single pin.
That 72ma will exceed the single pin rating of the AVR or of the 595 (35ma per pin). You need something with higher current capability than either of these parts for the column select.
Just curious-- you have tried the matrix with the 330 ohm current limiting resistor @ 5v and was it bright enough for your application? Obviously more current creates additional challenges, but better to figure out exactly what you need now so you can correctly size the other components.
