By kaiki
#39986
any idea what parameter one needs to change in Eagle to enable large sized connections from the walls of a via to a connected layer.
e.g.
By Azoore
#39988
DRC -> Supply -> Generate thermals for vias.
By kaiki
#39990
thanks.. i do have that enabled but it doesn't seem to do it.
I have also set the via(s) as SUP in the schematics.
The other settings in the supply tab in drc i have are:
Thermal Isolate - 0 mil (no restring)
Annulus Isolate - 0 mil (no restring)
i've tried with or without the restring option but it doesn't seem to change anything.
the only thing that shows up differently is if I set thermal isolate to 10 mils the size of the ring around the via (in the fill layer) increases.
By reklipz
#39991
Use the "Change" tool.
Click the wrench, go to "Thermals", then goto "On". Then, click the offending pour, and vuala!, there you have it.
By kaiki
#39992
sorry figured it out.. the layer wasn't specified as a supply layer.
Layer 2 $GND
took care of that.
