By fareez
#39672
dears
I used old eagle (dos)
I forgot the instruction to load an Ic from Lib to my new pcb design
pls refresh my memory
and if you have any referances
regards
By jandirks
#39744
This is how it is done for the current versions, not sure about the DOS version:
You can use the USE command to open libraries and find parts and you can use the ADD command to select an item to add to your schematic.
I hope this helps
