- Wed Dec 05, 2007 8:22 am
#39068
I am pretty new to the field of circuit design but I am keen to
learn. I would like to build a circuit for a project I am working
on. The design is extemely simple as far as I can see, however, it
uses a surface mount chip. Basically I want to convert TTL video
signals to LVDS. i.e. connector from graphics output -> converter IC -> hirose connctor to LCD panel.
I am thinking of using a chip similar to http://www.national.com/ds/DS/DS90C363.pdf
Basically I am not so sure I know exactly what is involved and can't
seem to find the information to help me. For example, I assume I
can't just create a design which simply wires up the connectors to the
IC? Some resistors are neccesary? Although I don't fully understand why they are neccseary and therefore how to calculate their values.
I want to create the design in the Eagle Layour Editor and get the PCB
made by batchpcb (I assume DIY methods would be hopeless at create
0.5mm pitch designs?).
If anybody could shed any light on how to proceed with this project I
would be most grateful.
Many Thanks
Many Thanks
