This is my first time ever designing a board, so I'm not sure how I can find out if the board meets spec.
The two pours (the left most and right most) are the power supplies, the airwires connect power to the other parts. I didn't bother connecting them if this part isnt "fabbable".
The grid is 6.25mil spacing, and I recall that BatchPCB has something like 7mil gap/7mil trace minimums, is that right? So at first glance, the chip as a whole has me concerned, as the gaps between pads for the LT1940 (the chip in question) doesn't even look fabbable.
Can you help me determine what I have to do to make this work? I know that that question is a little open ended in terms of what needs to be done, but thats exactly where I'm at right now, don't really know where to go / what
exactly it is that I'm doing (there are some really weird angles in there, polygonal pours doing weird things, chip doesnt seem to be aligned perfectly to grid or something, because it's not perfectly symmetrical (it should be, with exception to the lone trace under the chip at the top)).
The above paragraph proves my point, about not really knowing what I'm doing,
I really appreciate your help, as getting this single project under my belt is going to be a huge step forward.
-Nate
