- Thu Jun 21, 2007 9:46 pm
#31697
I'm trying to use the BatchPCB service for the first time and my design can't pass the DRC test. I made "clearance" and "distance" settings be 10mil or higher. The images, returned by bot, are all green and are not highlighted by orange or purple which are the signals of errors. What should I do to fix it?
Log file:
unmatched 274X paramblock OFA0B0 - len 6
Macro Name = OC8
Macro Consuming 5,1,8,0,0,1.08239X$1,22.5 [2]
PUSH 1.000000
PUSH 8.000000
PUSH 0.000000
PUSH 0.000000
PUSH 1.082390
FETCH 1
MUL
PUSH 22.500000
PRIM 5
Parse_OK
Arg: 0.0520
Looking up macro OC8 [0x54f140]
Beginning GCODE run
Ending GCODE run
Created 359 polygons
Found 0 errors
Partitioning....
Grouping...
Distance testing
MergeCount: 260
tests: 17541
Board boundaries: Rect: [0.075200,0.126400] -> [2.312200,2.276000], w: 2.237000, h: 2.149600
Found 99 groups
lengthdb size 0
DRC Error - trace to narrow
DRC Error - trace to narrow[/code]
Log file:
Macro Name = OC8
PUSH 1.000000
PUSH 8.000000
PUSH 0.000000
PUSH 0.000000
PUSH 1.082390
FETCH 1
MUL
PUSH 22.500000
PRIM 5
Parse_OK
Arg: 0.0520
Beginning GCODE run
Ending GCODE run
Found 0 errors
Partitioning....
Grouping...
Distance testing
MergeCount: 260
tests: 17541
Found 99 groups
lengthdb size 0
