- Fri Jun 08, 2007 10:39 am
#31091
So, I fubbed a board. There's a via right under my $35 gyro chip (IDG300) and I should've put a via restrict under there — so, I'm noticing intermittent shorts that I've pretty much figured has to be from that via shorting to the large ground pad on the IDG300. I'm figuring its that because the short never appears when I remove the chip, and it occured once, spookily, when I put a bit of pressure on the chip. Not good.
Anyone have any ideas about a ood way to "patch" that via? Just put a bit of some kind of material over it so that its insulated somehow? Is there a special sort of bit of material that's similar to solder mask that I could just apply a little dab of? Something that won't fry when I hot-air the chip on?
I saw the thread on solder resist material, but no one seemed to find a material that would do this. So, I'm trying again from a different angle — not about making my own solder mask, but trying to do a little DIY fix for an existing board.
Thanks for any help!
Julian
Julian
http://www.nearfuturelaboratory.com
