PCB Hole size to use with ISP Pogo Adapter
Posted: Tue Oct 10, 2017 2:35 pm
by perigalacticon
Designing a PCB and need to know what hole size to use with the Sparkfun ISP Pogo Adapter:
https://www.sparkfun.com/products/11591
It appears that it works with the std 2x3 ICSP pin header footprint, is this correct?
Re: PCB Hole size to use with ISP Pogo Adapter
Posted: Sun Oct 14, 2018 2:32 am
by Piquan
Yes, it's for the 0.1" pitch 2x3 ICSP header footprint, just like the one on an Arduino.
Pogo pins don't strictly need holes, although a hand-soldered pogo jig like this is easier to get lined up if you have them. Just stick with your usual via size; anywhere between 0.6-1.0mm works well (just testing with my pogo adapter and a template I have with various hole sizes drilled in it).
Posted: Sun Oct 14, 2018 3:57 am
by Piquan
PS: Sorry to necro the thread; I hadn't checked the date!
