By ti_chris
#188625
I'm getting 3 Eagle overlap errors while trying to route a line through a MCP23017ML. It's a QFN package and I'm going through the center heat pad to connect some GND pins together (pin 11-13 + 6 are all GND so I made them go through the center). It seems like a reasonable thing to do, but it's not exactly happy about it. I know that I can approve the errors, but wanted to check if I can do this or if I would be best to route those lines around the chip
Thanks,
Chris
By skimask
#188626
Does the center heat pad have a 'name'?
How about the line you are drawing?
By Ross Robotics
#188628
If you are using a ground plane (which you should), there is no need to connect GNDs. Reiterating what skimask said, the heat pad should be named GND.
By skimask
#188629
Ross Robotics wrote:If you are using a ground plane (which you should), there is no need to connect GNDs. Reiterating what skimask said, the heat pad should be named GND.
....ya know how many years it took me to figure that one out?....
In those 3 seconds when I figured it out, I slapped myself a dozen times, stepped on my own toes, banged my head against block walls, laughed, cried, drank drain cleaner, chewed on ice, and a few other things :D
By Ross Robotics
#188631
lmao! :lol: :clap:
