- Fri Jan 22, 2016 1:05 am
#187494
I looked in the default library, there are many 64 pins qfp but they all are 16 pins by 16 pins square style. The one I need has 13 pins by 19 pins rectangle package. Maybe I am using the wrong term? Is there a different term for non-square qfp? Worse, there is no spec I can find for NEC HuC6201 chip so I can't get accurate size or space information.
I believe the HuC6201 is a propriety CPLD by NEC and it was out over 20 years, I doubt anyone at company can help me with this, NEC went through a few merges and separations and I doubt anyone there still have original datasheet.
The pad looks like this: http://i.imgur.com/zGiHcnO.jpg and I haven't been able to find a different chip that used the same rectangle package size so I haven't been able to dig up a datasheet for the soldering pad detail.
Can anyone tell me where I could look up for the correct size and spacing for making one in Eagle or if someone has made a generic solder pad for this footprint?
