- Sat Nov 21, 2015 7:08 pm
#186076
I'm trying to print my circuit board on transparencies but I'm having some issues. It seems to be printing the solder mask as well as some other problems. On the top side, I have some SMD caps. When I hide the top layer, it still shows the outline of the SMD caps from the top layer. How can hide these? Also, the LED symbols are showing. I believe this is called the solder mask layer. Can anyone suggest the various layers I should turn off to print just the traces, pads and via's so I can print the board on transparency and then transfer it over to a photoresist board? Thanks!
