- Fri Nov 13, 2015 1:25 pm
#185895
I'm having trouble with Eagle again. I'm almost done with my board, but for some reason, there's a few air wires left. I poured a ground plane and I think I did that successfully. I added some solder pads to the design. 4 VCC and 4 GND. The four VCC pads make a cross across the whole board and one of the traces run into a trace that goes to a UV LED (as it's supposed to). I want them to become one trace like that. But for some reason, there's still an air wire from the VCC pad to the UV LED. Almost as if Eagle doesn't realize the traces come together as one. Any idea how I can fix this?
I have similar problems with the GND pads. There's air wires going from each pad in each section to a component in another section of the cross that the VCC pads make. I changed the value in the schematics for the VCC pads to VCC and I've changed the pads values for the GND pads to GND. Just not sure what I need to do. I'm still very knew to making circuit boards and I still have a lot to learn. Any help would be greatly appreciated.
I've attached a picture so you can see what I'm talking about.
Thanks.
Thanks.
