- Sat Aug 15, 2015 8:49 am
#184057
A few quick notes...
Schematic:
- Missing bypass caps on processor (one on Avcc. one or two on Vcc, placed right next to the chip)
- Recommend standard pinout on ISP header
- Recommend adding ground to headers that don't have it
- Add headers for other I/O? ADC6 and ADC7 are only ADC, not GPIO
- Stylistic - it's better not to have 4-way junctions on a schematic; makes it easy to miss one where the traces should connect but don't or vice versa. Better to do two 3-way junctions instead
PCB:
- Footprint for USB connector should have the outer mounting pads extending past the left and right edge of the connector and should have vias tying the pads to the board for mechanical strength. Too easy to rip the connector off the board without them. Same for the LIPO connector.
- There's very little clearance between the LIPO connector ahd the 4-pin header; will you be able to get the plug in? Does the plug fit flush to the board? Mught be better to rotate the connector 90 degrees clockwise.
- Check clearance betwen trace connecting C2 and C3; looks like it comes very close to the other pad of the caps
- Is the resonator footprint on the right side of the board? It's blue on the topside picture, and shows up on the bottom side, shorting to the trace from R7 to D1
- PWR and VCC traces look quite thin. Should be wide for lower impedance.
- Any restrictions about via, pour, or traces beneath the radio? At least tent the vias on the bottom side so as not to short out to vias or pads on the bottom of the radio PCB
/mike
Schematic:
PCB:
/mike
