By ipburbank
#182255
I am using the BEAGLE_BONE_BLACK_CAPE from the Sparkfun library which has the outline of the cape on the tDocu layer. How can I indicate to a fab that I want that to be the edge of the board? Can I also use that profile as the edge of my GND pour?
Thanks,
Istvan.
By Ross Robotics
#182259
You can change the layer type with the change tool.
By ipburbank
#182262
Having already wired up my board (except the ground pour), here is what my tDocu layer looks like: Image
I don't want to change the entire layer, just the outline of the board.
How can I extract that shape to use for the pour? And how can I use that shape to make a dxf (or is there a better way to indicate to a fab that I want that shape?)
By Ross Robotics
#182273
You can use the copy and paste to get the outline for the ground pour. You select just one segment at a time to change it.. It's the button that has a wrench on it.. Select layer, then the dimension layer and click on the segments you want to change.
