By beanx10
#180930
Hi...i'm getting crazy triyng to generate this Gerber files correctly from Altium....all the layers are Ok but the Top cooper layer and Top solder mask layer it shows little dots that i can't find on the PCB file...if anyone knows how to correct this please share....I don't know if this is a bug on the altium software or what....thanks in advance for the help...
By Ross Robotics
#180941
What dots?
By andyFraser
#180958
Go back to your PCB design and select Edit->Select->Outside Area. Draw a box around your board then press the delete key to remove any track fragments outside your board outline.
No try re-generating your gerber files.
Andy
By Ross Robotics
#180964
Ah, those dots.. I was looking at the board.. lol
