By flavius.stoichescu
#176846
Hello, I have a small project for a friend that needed a RFID reader with Ethernet and one cable connecting the little thing. I used the SparkFun PoEthernet Shield (DEV-10864) schematics, changed the passives to more solder-able smds, added everything needed for an Arduino Pro Mini and ID-12 RFID module, ordered the PCB and all the components but now I can't find the MagJack PoE compatible connector.
From the pictures of the SparkFun shield and much google-ing I found that the one used is the HR931147C from HanRun. Can anybody please tell me from where could I get this connector? Or something with the same pin-out? The MagJack on the SparkFun shop (which I initially ordered) is not PoE compatible (and I only later realized the difference since I'm a noob when it comes to Ethernet), and since I have already made the PCB and practically soldered everything, I can't use another connector but the one used by the shield.
Thank you very much for your help.
