- Fri May 09, 2014 5:48 am
#170954
I need to create a double layer pcb where some wire on bottom layer should be without solder mask to add more tin to increase the thickness.
See my actual pcb and the bad work to remove solder mask.
http://www.audiodesignguide.com/Ibridone/pcb2a.gif
http://www.audiodesignguide.com/Ibridone/Ib2014_ph0.jpg
http://www.audiodesignguide.com/Ibridone/Ib2014_ph1.jpg
Pads or Vias can solve my problem or both these will create wires on both layer ?
