By neuro11
#169503
I could not find any option in ultiboard about changing the circular antipad to square. But in the power plane properties I could change clearance of antipad to pad. So I did that. now they are not overlapping with square pad but they are overlapping each other...do you think that's a problem???
By n1ist
#169545
The ground-plane slots should not be an issue with this board. Pin 1 of the IC, however, still looks like it is shorted to the plane.
/mike
By neuro11
#169547
n1ist wrote:The ground-plane slots should not be an issue with this board. Pin 1 of the IC, however, still looks like it is shorted to the plane.
/mike
No I have zoomed and checked its fine.
Thanks for your helpful feedback....
