- Mon Dec 16, 2013 9:43 pm
#166592
Dear all,
here i am trying to run a motor in manual and auto mode. When running in manual mode linear get direct supply and when running on auto , it should drive from micro controller.And how to add diode in order to avoid spark when running in manual mode.
Switch:http://www.colehersee.com/home/spst_spdt_dpst_dpdt
Data sheet of motor Driver attached below:
http://www.nex-robotics.com/images/down ... e%20V2.pdf
Best Regards
Ajit Nayak
Ajit Nayak
