- Thu Apr 04, 2013 7:43 am
#157861
I have a PCB that I etched, however because it is the first one I've done it is a bit dodgy and has a lot of solder bridges to fix gaps in tracks. It also has a small wire soldered to the copper side as I forgot to lay a trace. Therefore I am aware that this makes it slightly vulnerable to being knocked and the wire coming off or something and it breaking the circuit.
So I am looking for a way to hold everything exactly as it is and prevent any damage occurring to the underside of the board.
The first thing that springs to mind is to just cover the underside of the board in glue gun glue so it is held as it is forever (of course I would only do this once everything is definitely working). But I haven't heard of anyone else doing this.
Looking on the forum I saw someone suggest this: http://www.all-spec.com/products/2106-1 ... 4AodYRSwYg But I don't think this would protect the soldered wire on the underside of the board.
Would glue gun glue work? Or has anyone else got any other suggestions?
