- Tue Mar 26, 2013 11:13 am
#157465
I am fairly new to electronics and very new to PCB design. I am trying to create a row of LEDs that are RGB controlled in small segments using a TLC5940 to either make downlighting or for lighting artwork for different effects. I will be daisy chaining up to 10 together, but I want to design my PCB to have both the LEDs and the TLC5940 on one PCB and then be able to connect to additional copies of the PCB. So all these PCBs need to lay flat in the same plane. How can I best connect PCBs to each other for this? Right now I have thrown in a shrouded 10 pin header which i could connect via ribbon wire (https://www.sparkfun.com/products/8506). but this seems like it is unnecessary and large. I need 8 pins at least. What other options are there?
The image of my schematic can be seen in the link below.
Thanks!
http://beerandelectrons.files.wordpress ... schem2.jpg
Thanks!
