rithi3 wrote:Thank you for your reply. Actually I do this for stretching the trace. Is there any option to stretch the trace to avoid the bends?
I'm not quite sure what you're alluding to, but I presume you want to rip up a trace from a via (preserving the via), then you want to re-route the trace so it connects to the via in a different path.
If this is what you mean, here's what I do.
- Hide the Unrouted layer.
- Rip up the trace going to the via up to the point that you want to correct.
- Show the Unrouted layer.
- Use the Route function (NOT the Move function) to continue the trace, automatically mitering any corners.
- Reroute as desired.
It looks like 5 steps is a lot, but you'll really fly through these steps with practice.
