By Mach3Maelstrom
#152361
Hello again! I've searched several forums & documents and spent hours testing several solutions, but can't seem to figure this out...
I need to take my .sch and .brd (or gerber files) and convert them into vector-font PDFs. This way, I can search for "R4" in the PDF and it will highlight the part.
This is for documentation, so I need these in PDF format -- any other format won't work for this purpose here.
I've tried:
  • Ghostscript
  • Ghostview w/ PStoEdit
  • PrimoPDF
  • Printing my files to PDF/PS, and
  • Converting to DXF and converting with AutoCAD DWG/DXF to PDF converter
These all produce a PDF that I can open with Adobe, but I can't search for text. I may have done one of the above incorrectly, so please help guide me in the right direction.
Thanks in advance!
By Ross Robotics
#152369
Try PDFFactory.
By Ross Robotics
#152458
hmm. Google some tutorials and see if your skipping a step. You're running Eagle 6.3, right?
By Mach3Maelstrom
#152750
Yes, I'm running the latest Eagle Standard package and the latest PDFFactory freeware. I couldn't find such a tutorial after several hours of searching (I always search for answers before I post in the forum).
I searched the EAGLE help for "pdf" and got the following:
If the output file name has an extension of ".pdf" (case insensitive), a PDF file will be created. A PDF file can also be created by selecting "Print to File (PDF)" from the "Printer" combo box in the print dialog. Texts in a PDF file can be searched in a PDF viewer, as long as they are not using the vector font.
I have "always use vector font" on for proper gerber creation, but even after changing the font type in the schematics, it doesn't work...
By Ross Robotics
#152755
Unfortunately, I cannot think of anything else being I am not at your computer. Maybe someone will chime in with an idea.
