- Tue Jul 17, 2012 11:36 am
#147491
I would like to connect an STM32F4 board -- which has two 50-pin (2x25) connectors -- to another home-made board. I only need access to about 10-12 of those 100 pins. I'd like to use 2-3 small ribbon connectors to do the job, but all of the ribbon connectors that I am seeing online have ends that are too "thick". In other words, the ends of the connector will not fit in between the pins that I am using and the pins that I am not using. I'd rather not cut the unused pins on the STM, so I can use it for other projects as well.
I am hoping that someone can point me in the right direction to find a cable that will fit.
Thank you.
-Bob
Thank you.
-Bob
