Well...let's READ thru them and figure it out, shall we?
1 Top Tracks, top side - tracks on the top side
2 Route2 Inner layer (signal or supply) - tracks on an inner layer
3 Route3 Inner layer (signal or supply) - tracks on an inner layer
4 Route4 Inner layer (signal or supply) - tracks on an inner layer
5 Route5 Inner layer (signal or supply) - tracks on an inner layer
6 Route6 Inner layer (signal or supply) - tracks on an inner layer
7 Route7 Inner layer (signal or supply) - tracks on an inner layer
8 Route8 Inner layer (signal or supply) - tracks on an inner layer
9 Route9 Inner layer (signal or supply) - tracks on an inner layer
10 Route10 Inner layer (signal or supply) - tracks on an inner layer
11 Route11 Inner layer (signal or supply) - tracks on an inner layer
12 Route12 Inner layer (signal or supply) - tracks on an inner layer
13 Route13 Inner layer (signal or supply) - tracks on an inner layer
14 Route14 Inner layer (signal or supply) - tracks on an inner layer
15 Route15 Inner layer (signal or supply) - tracks on an inner layer
16 Bottom Tracks, bottom side - tracks on the bottom side
17 Pads Pads (through-hole) - pads for a through-hole
18 Vias Vias (through-hole) - vias for a through-hole
19 Unrouted Airwires (rubberbands) - unrouted airwires, wires that are "in the air", so you know they have to be routed yet
20 Dimension Board outlines (circles for holes) - dimensions for various components on the board, or the board itself
21 tPlace Silk screen, top side - silk screen on the top side, you know, letters and stuff
22 bPlace Silk screen, bottom side - silk screen on the bottom side, can you guess?
23 tOrigins Origins, top side - origin, as in the beginning, maybe a reference point of some sort
24 bOrigins Origins, bottom side - origin, as in the beginning, maybe a reference point of some sort
25 tNames Service print, top side, I could go on but I'm not going to go on
26 bNames Service print, bottom side, maybe this link will help
http://www.sparkfun.com/tutorials/108
27 tValues Component VALUE, top side, maybe this link will help also
http://www.edaboard.com/thread135818.html
28 bValues Component VALUE, bottom side, but if that fails
http://lmgtfy.com/?q=eagle+pcb+layers
29 tStop Solder stop mask, top side, by now there should be some good info presented
30 bStop Solder stop mask, bottom side, by now the O/P should have started doing some reading
31 tCream Solder cream, top side, and should have a good idea of what's what
32 bCream Solder cream, bottom side, and by now I start stopping
33 tFinish Finish, top side, and I've stopped
34 bFinish Finish, bottom side, and left the rest of the layers to the O/P's imagination
35 tGlue Glue mask, top side, yep done
I ignore "one post wonders".
