Using SFE's 1.27mm through hole
kirash4
Post by kirash4 » Tue Oct 04, 2011 3:06 pm
From SFE's EagleCAD library, I'm trying to use the 4-pin 1.27mm through hole part (1x04-1.27mm). But, BatchPCB kicks it back to me with a spacing error. So, can we not use that element then? If so, why bother including it in the library?
phalanx
Non-SFE Guru
Re: Using SFE's 1.27mm through hole
Post by phalanx » Wed Oct 05, 2011 7:09 am
Because not everybody uses BatchPCB to make their boards. While BatchPCB and Sparkfun both make use of Goldphoenix, BatchPCB requires larger tolerances to keep the prices low for 1 piece orders. When Sparkfun orders production quantities from Goldphoenix, they are allowed tighter tolerances because the price is spread over a much larger order.
-Bill
