- Sun Jan 30, 2011 2:02 pm
#118777
why is it that putting a via near a pad of the same net makes a board non-manufacturable?
-Also, why is it bad practice?
I have been told to re-do a double-sided layout because i have a few 0.6mm/1.2mm vias just 0.1mm away from SMD resistor pads of the same net.
...the via "restring" is not touching the pad of the resistor....as i said, it is 0.1mm away...and in any case, it's of the same net.
(-the vias are 0.6mm drill, and 1.2mm overall diameter)
So do you know why this is a bad thing?
