- Thu May 20, 2010 10:54 pm
#101487
I'm trying to build a new component footprint for the sparkfun RGB LEDs (part# COM-00105) in Altium designer, and the data sheet doesn't seem to give the pin spacing or size. I looked at the Eagle files from the sparkfun button pads, but the LED spacing seems to be pretty wide (2.54mm or 100mil apart) and the through holes seem to be about 1mm or 40mil. I found a kingbright 5mm RGB LED data sheet that has spacing info, but its considerably smaller (which would be better for my project). The pins are 1.27mm or 50mil apart, and the pins seem to be about 0.7mm or 27.55mil wide. Which one should I go with? My gut says the Kingbright is the right size, but then again doesn't the sparkfun PCB use the COM-00105 RGB LEDs?
Any help would be greatly appreciated,
Owen
Owen
