- Mon Dec 07, 2009 7:36 pm
#86705
I'm designing my first PCB for SMD components in Eagle.
About this SMD inductor (see datasheet page 1 http://www.bourns.com/data/global/pdfs/SRU1038.pdf) I'm doubting about drawing the package.
As you can see this component has its pads underneath the package (slightly visible from the side when I inspect the real thing), so would I be correct if the "recommended layout" in the datasheet is only for reflow soldering, and I need to make the pads much wider to do this by hand soldering?
