Eagle layer color selection
Posted: Mon Aug 31, 2009 10:55 am
by kacper
The display dialog's color selection seems to be missing some colors on my installation. For example I can not select white as a color for the tPlace layer. I see two rows of colors and the rest are all dark grey. Anyone who knows how one can select more colors?
Windows 7
Eagle 5.6.0
Posted: Mon Aug 31, 2009 1:54 pm
by theatrus
Are you doing something silly such as running under 256 color compatibility mode? I haven't tried Eagle under Windows 7 either, so it could be a compatibility issue.
Posted: Tue Sep 01, 2009 7:45 am
by kacper
I'd figured it out. In the board editor under Options - Set... One should turn of "Use alpha blending". Having the bottom and top layer on at the same time gives a rather fashionable color if you turn alpha blending off. Perhaps adding the colors manually by setting the "Alpha channel" to 255 is a better approach.
Any idea what alpha blending is?
Posted: Tue Sep 01, 2009 8:47 am
by TheDirty
It's a way of mixing the different layer colours, so you can see through top layers and see layers underneath.
Re: Eagle layer color selection
Posted: Fri Dec 09, 2011 2:15 pm
by sparky
Version 5.11 on windows 7 seems to lock the palette now. A command will fix spot 16 to white:
set palette 16 0x00000000;
