- Sun Jul 06, 2008 6:30 pm
#51418
I have been looking for a circuit to do the following ...
I have a very low power PIC application that basically logs data every few minutes in a very low power mode, doing so for months at a time with occasional wireless downloads of the logged data when a fair amount of power is required for a few minutes, the box will be outside and I'd really like to supplement a Li-Poly battery with a Solar charger to keep the battery topped up when possible, running from the battery as the Vcc for the circuit.
Challenges I'm trying to fix are ..
- finding a small enough, yet powerful enough solar cell, I think the SFE PRT-07845 should do the job nicely.
- Finding a Li-Poly charger that specifies the Minimum input voltage and current required for it to start charging a 2000mAh Li-poly battery(SFE PRT-00340)
- Figuring out if I need a voltage step up stage before the charge IC to get the charger circuit to work properly from the Solar cell ?
Anyone have any experience with this kind of thing...
