By Ramune
#49873
My board keeps coming out at the wrong dimensions because the little + sign used to move objects is outside my board. I use Eagle and nothing shows up in Eagle but when I process the files and view in Viewmate I can see the little + signs. How can I get rid of these?
By gm
#49879
When you are generating your Gerber files using one of the CAM files, make sure the tOrigins and bOrigins layers are NOT checked.
Hope this helps,
gm
By Ramune
#49880
Thanks, I got it fixed. I tried a few things, not sure what worked but I'm pretty sure just clicking delete in the areas where the little + signs were worked.
By Philba
#49913
let's hope you didn't delete components you needed...
