- Fri Jun 06, 2008 3:20 pm
#49776
hi,
newbie's first post here. i'm planning to use a luxeon 3W led as a beacon pulsed intermittently. since i wont be using it continuously do i need to worry about heat dissipation? or can i just solder direct to the pcb using the sfe provided footprint.
as far as using the aluminum breakout board, i figure i could fasten it to the pcb with some spacers so that the aluminum backing is exposed to air, but then how to get the power and ground connections to it?
thanks,
denki
thanks,
denki
