- Sat Jan 10, 2009 12:01 pm
#63217
circuit is the correct PCB layout. You came here asking:
and intended to fab and build it.
Also, why run inputs and outputs from a high gain (26dB) amplifier
next to each other? This has nothing to do with EAGLE.
You are not at a point to understand that such a circuit is doomed.
discussion of his favourite PCB software would scare
away anyone!
"eagle' and 'leon_heller'. leon_heller jumps on most PCB newbies to
pitch his bloatware. EAGLE is not easy to learn, but has quite
a good price/performance for hobby needs.
You are one of several new members that have brought a
specific EAGLE problem here, and been told by leon_heller
you are wrong to use EAGLE. (But leon_heller will import your
EAGLE work into another tool and lecture you on your errors!).
By baiting leon_heller we see this behaviour in a better light.
BTW, leon_heller is compensated by the other tool's publisher.
I've purchased my own copy of EAGLE.
SpikedCola wrote:True, however I never claimed to have designed the circuit - in fact, I used a previously designed and tested circuit because I know that it will do what I want, and it has been tested (this saves me having to troubleshoot schematic errors and just leaves me with design errorsJust be aware that most of the 'success' of that
SpikedCola wrote:this is the first thing I have ever designed/created in Eagle...You gave the impression that you had created this PCB,
If you have any comments, suggestions, etc, please let me know!
SpikedCola wrote:V=IR Im very familiar with Ohm's LawThen why run amperes of current through 25mil pin headers?
SpikedCola wrote:I have done nothing of the sort! :) Actually, Im on the last day of my cruise.Fine. I was addressing leon_heller. His passionate
away anyone!
SpikedCola wrote:Again, not trying to defend leon, nor bash you, but it sounds to me like he was simply saying that Eagle isnt the best tool to use to autoroute my boardDo some homework. Use the search on this forum to find
