USB data received packets...
USB PICs and the UBW
dtvonly
Post by dtvonly » Thu May 16, 2013 10:51 am
Please see attached simple sample USB code. One part I do not understand is how the received data is placed in the 2nd element in the btnGetPBState_Click subroutine? Please clarify. The code did not take me to the correct definition of the Read routine therefore I don't know how the received data is placed in the USB received buffer. thank you in advance.
Imports HIDLibrary
Imports System.Threading
Public Class Form1
    Dim HidDeviceList As HIDLibrary.HidDevice()
    Dim AnyHidDevice As HidDevice
    Dim HidDevice_detected As Boolean
   Private Sub btnGetPBState_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnGetPBState.Click
        Dim OutData(AnyHidDevice.Capabilities.OutputReportByteLength - 1) As Byte
        'Dim InData(AnyHidDevice.Capabilities.InputReportByteLength - 1) As Byte
        Dim DataFromTarget As HidDeviceData
        Try
            If Not AnyHidDevice.IsOpen Then
                AnyHidDevice.OpenDevice()
            End If
            OutData(0) = &H0
            OutData(1) = &H81
            AnyHidDevice.Write(OutData) 'Send out report to get push button state
            DataFromTarget = AnyHidDevice.Read(250) 'Get input report
            If DataFromTarget.Data(2) = 0 Then 'Element 2 contains the button state ??????? how????
                Label1.Text = "Pressed"
            ElseIf DataFromTarget.Data(2) = 1 Then
                Label1.Text = "Not Pressed"
            End If
        Catch ex As Exception
            DisplayException(Me.Name, ex)
            Throw
        End Try
    End Sub
Edward Ronald
Re: USB data received packets...
Post by Edward Ronald » Thu Jun 13, 2013 9:43 pm
Thanks for sharing valued information with source code. This is acknowledging for me and helpful to save my precious record.
