I had not tried the Teensy but used other processors on the carrier board. The screen needs to be set reversed.
During my tests I was dissatisfied with the provided libary. Only for the screen not for the buttons, APA102 LEDs and tone. I have created a number of libaries. Some based on what others had done for other boards, some nearly from scratch. Give it try they are on
https://github.com/paulvha/MicroMod and let us know.
Just did the test with the Teensy and it needs adjustment in the top of the sketch.
For now change it to:
Code: Select all// MicroMod Input and Display carrier board
#define bl_pin CORE_PIN0_BIT //PWM0 // background light pin
#define TFT_CS CORE_PIN2_BIT //D0 // TFT CS Chipselect
#define TFT_RST -1 // TFT RST No reset used
#define TFT_DC CORE_PIN3_BIT //D1 // TFT DC Data command
As I find more time I will update my libraries in a better way.
