- Tue Jun 07, 2022 7:10 am
#233876
I am using SparkFun MicroMod RP2040 Processor (https://www.sparkfun.com/products/17720) on SparkFun MicroMod Data Logging Carrier Board (https://www.sparkfun.com/products/16829)
The I2C fails to talk with i2c devices (have tried several devices).
I try to debug the port so I checked SDA/SCL with oscilloscope using https://github.com/raspberrypi/pico-exa ... bus_scan.c
The clock falls to 0V.
The data "falls" 2.6V
I disconnected pullup resistors and using the internal pull up
Any suggestion why I am not see the SDA falls down while requesting device address?
gpio_pull_up(PICO_DEFAULT_I2C_SDA_PIN);there is no devices that connected and I see only one fall of the SCL (instead of at least 8 of the address).
gpio_pull_up(PICO_DEFAULT_I2C_SCL_PIN);
