- Wed Feb 06, 2008 1:07 pm
#42378
Try the following to recover - as a last resort.
Normally you should not get this problem with the str9, we have quite e few people using the comstick.
# config script
flash bank str9xpec 0x00000000 0x00080000 0 0 0
# then try unlock
str9xpec enable_turbo 0
str9xpec unlock 0
then cycle board power.
Are you sure you have killed it, post the openocd log - openocd -d3
you could even try a lock/unlock sequence.
Cheers
Spen
# config script
# then try unlock
str9xpec unlock 0
Cheers
Spen
