- Tue Jun 12, 2007 12:59 am
#31181
we have some annoying problems with our ARM-USB-OCD
JTAG interfaces from OLIMEX.
They work fine when connected to a PC with a short
thick USB cable.
Using our normal somwhat thinner and longer cables
they turn themselves off.
I have the larger voltage drop on the cable under suspicion,
but not quit sure.
In the USB spec I found that every USB device has to work
from (alt least) 4.75V to 5.25V.
As there goes some dynamic signaling on, its not easy to
measure the voltage correctly.
But when the ARM-USB-OCD goes idle I measure 5V on the
longer cabel an 5.06V on the shorter one.
I read here something about connecting the interface to an
USB hub.
I wonder what the Olimex people say to this.
From my point of view this device is not designed
to work on a standeard USB port!
Maybe there is some hardware patch available, especially
when not using the interface as a power source?
I think the FTDI chip works with lower voltage level (4,35V)
when powered from USB.
Regards,
Joerg
thick USB cable.
but not quit sure.
USB hub.
Regards,
Joerg
