OpenOCD startup error with Olimex ARM-USB-OCD-H and Galileo
Open source ARM Debugger
Postby hmerovich » Mon Jul 03, 2017 6:43 pm
I am trying to test source level debugging with a OLimex ARM-USB-OCD-H jtag adapter and my Intel Galileo Gen 2 board but when i try to start openocd I get
openocd -f /usr/share/openocd/scripts/interface/ftdi/olimex_arm_usb_ocd_h.cfg -f /usr/share/openocd/scripts/board/quark_x10xx,board.cfg
Open On_Chip Debugger 0.8.0 (2017-06-26-22:51)
Licensed under GNU GPL v2
Info: only one transport option: autoselect 'jtag'
adapter speed: 4000 kHz
trst_only separate trst_push_pull
Info: clock speed 4000 kHz
Info: JTAG tap;quark_x10xx.cltap tap/device found 0x0e681013 (mfg:0x009,port:0xe681, ver: 0x0)
Error: quark_x10xx.cltap: IR capture error: saw 0xff not0x1
Warn: Bypassing JATG setup events due to error
Pls can you help me to solve the problem?
Best regards and thanks in advance
hmerovich
Return to OpenOCD
Who is online
Users browsing this forum: Bing [Bot] and 1 guest
cron
